Ragazzi aggiungo una guida per riparare i cavi 704.1, 805,0 - 805,01 , 812,4 purtroppo è in inglese vedo se riesco a trarre una traduzione
Step1: Please ensure that you have installed the VAG-COM software.
Step2: Plug your disabled cable to the USB. There maybe be a pop-up window to indicate you to install the driver, for damaged cable, let it be, skip it.
Step3: Right click "my computer", select " hardware", then "device manager", then "Other device", the " USB device".
Step4: Right click "USB device", select "properties", select " detail", there will be a line information displayed. VID_xxxx & PID_xxxx, please write down the 4 letters or number for VID and PID.
Step5: Unplug the cable, select" my computer" --"C:/"--"Program files"--"VAG-COm"--"VAGUSB.inf".
Step6: In item [FtdiHw], please add one more line as " %USB\VID_xxxx&PID_xxxx.DeviceDesc%=FTD2XX, USB\VID_xxxx&PID_xxxx", please ensure the four number or alphabets are the same as the ones you write down in step 4.
Step7: In the end of the text, add one more line as " USB\VID_xxxx&PID_xxxx.DeviceDesc="VAG-COM Compatible USB Interface", the four numbers or alphabets are also the same as the ones you write down in step4.
Step8: Save "VAGUSB.inf" file and then exit.
Step9: Unplug the cable, and then plug the cable to the USB port. System will indication found new hardware, and will pop up window for driver update. If do not have the pop up window, let it be, Right click "my computer", select " hardware", then "device manager", then "Other device", then right click "USB device", select update drive.
Step10: Let the driver point to C:/program files/vagcom
Step11: System will search the drive for several seconds, then it will indicate that find the driver and then install it.
Step12: Open the software "vidpidfix.exe" i sent you. Click "search", there will be indication two lines of information. First " found one device", second "0".
Step13: Click "0", then click "open", the information will be displayed in he blank dialogue. Click "write default EE data", if success, there will be a pop up information " wirte successful". Then click "ok" and exit.
Step14: Unplug cable and then plug cable.
Step15: Just as the step 10, update the drive and let the file point to the file "VCR_CDM 2.00.00" that i send you. There will be a indictaion information that it install completrly.
step16: Open the file" Mprog2.8_setup.exe". Click" device" and then"scan", if above steps are all well done, there will be information " find one device".
Step17: Use Mprog2.8.exe to open file " genius vag com ept.ept" that i sent you. Then click "erase", if succeed, there will be a information " successful", and then click " program" , if succeed, there will be a informtion " programmed serial under disabled"
Step18: Your computer can recognize the cable now and your cable is ready to use.
file di riparazione
x vag-com 704,1
x vag-com 805,0 - 805,1
x vag-com 812,4
suggerimenti per non bruciare i vag-com
SEGUITE ATTENTAMENTE LE NOTE DI SEGUITO E NON AVRETE PROBLEMI CON IL CAVO OBDII CAN BUS.
IL CAVO FUNZIONA SOLO CON LA VERSIONE DI SOFTWARE 20070422 ( LO SI PUò NOTARE IN ABOUT)PER VAG COM 704.1;
E LA VERSIONE 20080823 PER VCDS 805.1
ALTRE VERSIONI PROVOCANO LA SPROGRAMMAZIONE DEL CAVO CHE DEVE QUINDI ESSERE RIPRISTINATO.
IL CAVO NON PUò IN NESSUN CASO PROVOCARE DANNI ALLA VOSTRA CENTRALINA, IN OGNI VOCE C'è
SULLA PARTE SINISTRA LE VOCI SICURE E SULLA PARTE DESTRA LE VOCI CHE POTREBBERO PROVOCARE
MODIFICHE AL FIRMWARE DELLA VOSTRA CENTRALINA CHE POTREBBERO COMPROMETTERE IL BUON FUNZIONAMENTO DELL'AUTO SE NON NE SI CONOSCE BENE LA FUNZIONE.
IL CD PICCOLO VIENE FORNITO DAL PRODUTTORE MA SU QUELLO GRANDE C'è TUTTO CIò CHE SERVE.
ESEGUIRE LA SEGUENTE PROCEDURA:
diasinstallate versioni precedenti di questo software
andate nella cartella che si trova in C:\WINDOWS\system32\DRVSTORE e cancellate la cartella rt-usb
cliccate sull'icona di zone alarm e quindi installatelo
riavviate il pc
CLICCARE SU VAG-COM-release-704.1-installer SE AVETE ACQUISTATO IL CAVO 704.1 OPPURE
CLICCARE SU VCDS-Release-8051-Installer SE AVETE ACQUISTATO 805.1
CLICCARE SU VCDS-Release-8124-Installer SE AVETE ACQUISTATO 812.4
il software verrà installato ( ci sarà un messaggio quando installerete i driver che windows vi avvisa che non sono riconosciuti ma non vi preoccupate e continuate) successivamente verranno installati i driver del cavo.
durante l'installazione zone alarm vi dirà che il file dll.exe sta tentando la connessione quindi voi spuntate: remember this setting e cliccate su deny
troverete al termine un'icona sul desktop del vag com / VCDS
riavviate il pc non connessi ad alcuna rete
inserite la spina usb nel pc e effettuate l'installazione dei driver.
all'avvio del vag com, zone alarm vi comunicherà che vagcom.exe sta tentando una connessione quindi: remember this setting e deny.
d'ora in poi zone alarm bloccherà in automatico la connessione e quindi non vi comunicherà più nulla.
Siate sicuri sempre che quando utilizzate il software non siete connessi ad internet, le precauzioni non sono mai troppe.
quindi cliccate sull'icona sul desktop e si aprira una finestra del programma e con una nuvoletta vi avvisa che il software è vecchio, cliccare sulla X.
cliccate su OPTIONS inserite la spina usb nel pc e cliccate su test: vi uscirà una nota che vi dice che è stato trovato un hardware rosstech chudete la nota.
inserite la spina obd nell'auto, la spina usb nel pc quindi girate la chiave e cliccate su test, se è tutto a posto e si tratta di un auto can bus vi uscira la seguente nota: k1 ok, k2 ok, can ok.
al termine riavviate
andate in START -->PROGRAMMI-->ESECUZIONE AUTOMATICA e cancellate la voce RT updater, evitate quindi di avere una connessione attiva all'avvio del pc in quanto questo software cercherà in automatico di connettersi!
se non trovate tale voce riprovate in un secondo momento
adesso potete utilizzare il software.
MI RACCOMANDO EVITATE DI COLLEGARVI AD INTERNET CON IL SOFTWARE IN FUNZIONE.
